2001 Kawasaki Bayou 220 KLF220A Ignition Switch
Go to solution Solved by Mech,
2001 bayou 220 KLF220A
I'm at a loss here. Thanks.
  • Admin changed the title to 2001 Kawasaki Bayou 220 KLF220A Ignition Switch
That download isn't working for me, for some reason. but it does stand to reason i may need a 2 wire switch, as all i have is a white and brown available on the harness.
Replaced the key switch, CDI box, and igniter, WE HAVE SPARK! just need to slap a carburetor on this sucker,and some new fuel line and tires.
What do y'all recommend for crankcase oil? assuming it has a Wet Clutch, so probably Valvoine ATV 10w40 will be my choice.
ju
Edited by TravisM
Valvoline is good oil, i have never used their ATV oil, i have been using Yamalube mineral oil, it has the best rating and is not that much more expensive than any other, i have also used Suzuki Ecstar in my Suzukis no issues. I have also used Rotella and Castrol no issues with any of them.
Well since i got spark, before i put a new carb on and all that, i figured i'd see if it'd pop over on some starting fluid.. gave it a squirt through the carb.. no go. made sure i had spark. i have spark. put a new plug in. Gave it a shot in the plug hole. no fire.
What gives?  I know i have fuel (since im introducing it directly), i have spark, a new NGK plug...
Well, it seems now i have no spark.... rechecked it.....
How can i go from having no spark, New CDI, Igniter and Switch, get spark. leave it alone for a day, come back. no spark.
Thats Bad, I think the first thing i would do is check all my connections and make sure they are good and tight. Im sure you have done that already. Does everything else seem to be working correctly, just no spark.
How often do the starter switches go bad on these things?  I can jump from solenoid, but nothing at the start button--also don't have neutral light or headlights/taillights...chasing some odd electrical
    • By marlon smith
    • By Gtc4d
      Thanks.
      Todd
    • By digrig
      Hey everyone,
    • By tds7
    • By dkgg5755
