The reason lawn care can get you in troble!!!!!!!!!!!!!
Yeah...that mowing deck doesn't look too secure...
Boom ching, bada bing!
-TD
id rather that truck be full of free quads!!:biggrin::yes::biggrin::yes::biggrin::yes:
Yeah..but then they'd come out in little pieces.....
-TD
    • By hunky
      Thanks for looking!
    • By p5200
      The studs in the sprocket hub are stripped out. The hub is probably walloed out also. Probably will have to have a new sprocket hub. I doubt I have the ability nor the tools needed for this job. Thanks for all suggestions/opinions!
      20240225_155255.mp4   20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4
    • By afterdinnerspeaker
      Hi Everyone!
      Recently, I could no longer start my Arctic Cat using the green starter button.
      Initially, the response was intermittant (sometimes it would start and other times in wouldn't).
      Finally, I get no response or sound by pressing the green button.
      I'm trying desperately to trace the wires from the green button but can't seem to follow.
      I took the button apart and cleaned the contacts but no difference (yet my instruments indicate contacts are OK).
      I inserted an image to show the wiring colors going into the green switch.
      I'm still able to start the machine by using a long screwdriver to short the starter.
      I'm hoping someone can help me find a possible break in the wiring or any other cause.
      Many thanks in advance to anyone who can help me!
      Jerry
    • By alexwv1863
      Hey everyone, I'm back again.  Some of you all may remember my posts.  I took last year off from working on this particular project.  It's a 2006 Arctic Cat 400 TRV (Green) 4x4.  I am at a loss as to why I cannot get it to run.  I have had someone suggest replacing the shift sensor.  Now, I have been looking in repair manuals and I just can't figure out where it's located.  I was told it was on the engine on the left side.  From the photo I found of one on eBay, I haven't seen anything that looks like it on the 4-wheeler.  Could it be called something else? Where is it located?  I know I'm overlooking it because I'm thinking it may have another technical name.  I feel that I will be making more posts asking for help once it warms up here.  I would really love to get this dang thing running this Spring.  I have 2 other different atv's that are requiring my attention.  So, I would really love to check this Dag blasted thing off of my repair list.  Any and all help will be greatly appreciated.  Thank you in advance.
