I think first i would try adjusting the clutch and see if that helps, and if the oil hasnt been changed in a while might try that, sometimes oil get contaminated and looses its viscosity.
  • Thanks 1
do this, Ive had that happen more than once
  • Thanks 1
Does it have an adjustable clutch ? I thought this would be a centrifugal clutch, in oil but not adjustable.
I'd check the idle speed is right first thing.
Mech you are right it is CVT. I guess when i hear hard shifting i think of actually manual shifting. Still i would change the oil and check the CVT system for proper operation , and definately idle speed, like Mech suggested.
Oh yeah me too mate. I always think of the foot shift first off when I see shifting problems, and I forget which bike it is we are talking about sometimes when I'm in several threads.. haha.
Clean primary clutch "one way bearing" pin+spring unit = That is between plate's...  When it start to stuck = You loose "neutral".. It will get really hard to "shift"..
I'm working with brp stuff ;)
Transmission oil would not stuck chance really easy...
I have this exact same problem on my2012  800r xmr and after checking everything over I determined the the inner sheave bushing on the secondary was worn out. This will cause the helix to wear and eventually break. These 2 parts are available aftermarket.   This will fix your hard shift problem.
    • By Coyote251
    • By neilroy87
    • By carkivey3
    • By Sportsman500guy
