2022 Hisun Sector 550 Gas gauge stopped working
By BuckBilly
By KSIM
By neilroy87
I have a 1990 Bayou 220 that runs pretty well for it's age--needs a new muffler, but sounds tough. Have had to start with a pull cord since I got it, and recently started troubleshooting the start button. Finding a lot of information on this issue in the forum, but haven't been able to chase it down yet. Got a new battery, new starter solenoid, and going to replace the starter relay this week, but not convinced that's going to do the trick, since I can't get the neutral light on when turning the key on. I can start it by jumping the solenoid, but the 2 black wires to the relay do not activate the starter. Bad ground or a short somewhere? Is there a good way to just test the ground?
By carkivey3
By jwh
I am new to this site. Now down to business, I have been given a Kawasaki 220, tires are trashed and it has been setting for a long time. Do I need a battery in it to find neutral? I know there is a neutral switch and if I shift down(7 times????) then up one using the neutral switch I should be in Neutral. As you see I am in a learning curve here ......coments welcome.
