By Gwbarm
By semicolon
By HSTAR
By bighoss
By Am2007
Hi everyone,
owner manual
service manual
engine manual
I have the first 2 but i can not find the last one, part number 219100232. If someone can guide me where do i find the oil strainer so i can clean it i will appreciate it. im going to do an oil pressure test tomorrow to check how many PSI i have, just to make sure.
