 I own a 2007 Polaris Sportsman EFI X2 model and have for the past months been experiencing loads of issues. Basically the Sportsman will only start if the throttle lever is pushed and will not remain on idle. This situation has persisted for months now and I have replaced the following parts:
Sparking Plug
Fuel Injector
Fuel Pump
Fuel Filter
Fuel Valve
Fuel lines
Power Control Module
The last part replaced was the Power Control Module and the Sportsman was tested and worked fine on a couple of occasions which were days apart so much so that some weeks later I took the Sportsman for an extensive ride and it worked perfectly. This was three weeks ago and today I tried to start the ATV it worked fine a few minutes and decided to switch it off so that I could continue with some prep work. A few minutes later tried to start it up again but noticed that it would only start if the throttle lever was pushed and once I removed my finger from the throttle lever the engine would not stay in idle and would simply shut down. Several attempts were made to start this and also tried to re-adjust the setting by turning the built in wheel like mechanism in the throttle cable but it was to no avail.
The above have been repeating itself on an off basis. Each time a part is replaced the ATV would work and then all of a sudden will not keep its idle. At this stage I cannot think of any other solution other than possibly some sensors which might have an intermitting fault but I cannot really say.
Would greatly appreciate any assistance.
Thanks in advance.
  • Admin changed the title to 2007 Polaris Sportsman EFI X2 Idle Mal-Function
here some thing you can check, i dont know if this model have a '' idle air control valve '' but this thing gums up over times, clean it or replace it ( if you have it on this engine), next you can check or replace throttle position sensor, some time this (potentiometer) have a tiny hole in a trace somewhere between 1% and 10% and what is meaning to pcm is'' i have lost signal, a can't do anything without signal''. why this tiny hole? overtime the engine vibration use the carbon trace and make this sensor defect.
this suggestion is made by logic and please, i am open to learn ! thnks!!
the best thing to do is call a friend with an oscilloscope or take yours to back probe this sensor to show the signal in real time, here you can see if you lost your signal instantaneity within 0 to 5vdc.
Hi Qcm. No mention of the trouble light coming on.. The trouble light should come on if the TPS has a too high or too low reading, and it should set a code of course. Also, I'd expect the engine to stumble if the TPS had a fault, but not perhaps die completely and instantly as I think(from the description), that this is doing.
Fuel pressure or that throttle cable switch seem like more likely things to me. It would be good to know what engine we are talking about..  haha. The eight hundred engine might have different software I think, in which the throttle switch might not be a suspect.. That switch does cause problems though, and it and low fuel pressure both don't set the light.
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
