I know this is a stupid question but here I am.. I'm wanting to have the ability to disable my taillight/brake light on my '96 Polaris Xpress at will, it comes on with the key and there are times I don't want it to illuminate. I have basic wiring knowledge and I'd like to put a toggle switch to disable it. I'm not sure of the wiring setup on this thing, can I just use a toggle switch on the ground wire to kill it when I choose? Can someone clarify which wire I need to work with and the easiest way? Excuse my ignorance yall.
Ok, I found the easily accessible plug at the light. 3 wires, one is constant for taillight, one is hot when the brake is activated, and obviously the third is ground.  I suppose I could just unplug/plug in the connector but I'd like to be able to turn it off/on while on the move and not have the connections exposed to the elements. Pretty sure I'm on the right track, just was hoping for confirmation.
I knew this was a stupid question for most but I was hoping someone could at least help with my admitted ignorance. I've never put a switch on a ground wire before and just want to make sure it won't cause any issues. Anyone????
Well on battery disconnects I only open the DCcommon.   safety of no com  if Bat + is grd to frame accidentally.  On a light yes I guess one could use a double pole discinnect but never two individual switches.   I don't like chasing open com's.
Maybe a simple three wire connector at lights.  Remember if you solder use only electrical solder.   I have made that mistake before...Off course I have made lots of mistakes ...LOL
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
