Magnet fishing on my ATV
Go to solution Solved by jen,
I travel a lot though open woods or privative abandoned road beds...tress without much underbrush. When I come upon areas where there is broken glass I stop and pick up or secure it.   I also drag my magnet around to see what else is there.   If there  is a hollow tree I will stash glass  in there or put in my Moose carrier.   I am thinking about dragging my magnet.  I can hear it "click" when it catches something big .  My best find so far is a log chain and an antique stone lifter (Used to lift foundation stones on log cabins into place.)
Must be one hell of a magnet :) Its neat to find history in the woods. That is why I like photographing abandoned railroads. Never know what your going to find.
Probably my oldest find was strap rail from a gravity railroad. Nearby I found iron couplers where were used to join two sections of wooden water pipes to feed water to the steam engines. I also found several iron ring straps which were hammered on the end of the wood logs so they don't split when installing the couplers. This dates back to the early 1850's
Earliest railroad I ever photographed was 1829, but there was no relics left, only the old grade.
I have seen commercial truckers have magnets hanging in front of their front wheels when coming into mfg yards to pick up nails.  I would like to get one of those to  suspend  behind Foreman.
I drag a strip magnet behind using a wire to attach it so only tail of magnet strip touches ground.  I listen for a click it it hits something.  However, I watch for signs that people have been in area like broken glass, obvious trail parking areas. Abandoned roads are the most common where I travel...These are roads that were horse and wagon traveled dirt or some corduroy roads and never maintained for 80 years.
An Old building a distance off  an abandoned road. It was actually the "fruit celler"  of an old cabin where they stored apples, potatoes etc.  Found  meat hooks and snakes there.
Old ruins
  • Solution
Here is meat hook.  The larger is a hay hook for square bales.  The meat hook was inserted in the eye of a hog so two men could drag the daed hog to a scalding barrel.  It was forge welded. I would probaby do better with a metal detector.
    • By Rich1028
      Quad Up on Two Wheels Through the Turn
    • By Hagbard
      Looking for a DRIVE SPROCKET RETAINER PLATE for a 1987 LT230E (P/N 24751-35B01)? Good luck.
      Believe me I searched high and low, including contacting two OEM suppliers in Japan. No dice.
      Ran into this problem myself. The part is no longer available, unless you get SUPER lucky on eBay.
      My solution was to use the identical part from the newer ones, but you have to switch out the bearing and spacer bushing as well. Basically I took the retainer plate (46) and spacer bushing( 55) from a 160 motor I have for parts, and bought a new 6206 bearing which is the right size to match part (40) https://www.amazon.com/Bearing-30x62x16.../dp/B07XJ7H2VJ There's also a difference in thickness between the sprockets, so I added a couple 14ga. bushings as spacers
      So, referencing this parts diagram, you need to get everything from the bearing (40) on out. So, parts 40 (BEARING 09262-30084), 46 (RETAINER 24751-35B10), 47 (OIL SEAL 09283-38017), 48 (O RING 09280-70009), 54 (O RING 09280-21008), 55 (SPACER 27531-35B10), and 59 (PLATE, FRONT CHAIN GUIDE 27641-35B00).
      https://www.babbittsonline.com/.../50d08495f.../transmission
      If you need me to walk you through any of it I'd be happy to help.
    • By LT-4WDinNY
      I got the side cover off, learned how to put the subtransmission back together. I took the nut off the crank. Grabbed the new flywheel puller. Put the small piece on to protect the crank shaft end, and the flywheel fell off on its own??? So that was weird. I then looked and tested the starter one way clutch. It wasn't in pieces like I had seen on others on YouTube. It only turns in the one correct direction as indicated by the arrow. However, it looks like maybe it is slipping under load? Is that possible?
      I know that it was very difficult to pull start since I bought it back in 2001. The guy I bought from had the receipts on a recent engine rebuild by our local Suzuki dealer in the $1200 range because they put the oil filter in backwards. Anyhow, I am trying to make it easier for my kids to ride. I think I verified that the starter clutch was bad by removing the electric starter, then it would pull start normal...
      I took pictures of the one way clutch and the CALTRIC replacement parts I bought off Amazon. Looking closer, appears to be heavy wear on the metal pieces in the clutch and scratches on the starter gear surface that goes inside the clutch. I am going to replace the OEM parts with the CALTRIC brand parts off Amazon.
      However, I found some other discerning things behind the flywheel. Looks like the center case has cracks, and one broken off tab with the other 2 worn? Also it looks like some scraping inside the case bottom right... assume from when the post broke off.  The post was NOT in the case, so probably occurred prior to the Suzuki Dealer rebuild.  Also some discoloring on the crankshaft and back of starter clutch.  Again, putting in the CALTRIC brand replacements for the starter clutch and starter gear as a set.
      Thanks!
      Bruce
    • By tkokenos
      I just recently purchased a Polaris xpress 300 and have had a number of problems.. I purchased it in none running condition and found that it needed a top end done.. after completing the top end and not being able to find the oil drain plug for the engine, any kind of dip stick to check the oil, or any where that I could fill the engine with oil I was already frustated enough.. and then when i finally did get it started and tried to put it in gear and it would just grind(no matter what gear) My frustation has become monumental.. any help with this problem would be greatly appreciated.. i've already tried to idle the engine down to it nearly stauling out and then tried putting it in gear and it would just grind, or if i tried to force it it would just staul out completely.. for fear of tearing up gears I would like some input procede any further..
      Thomas,
    • By Jeff Comstock
      So it's been a while since I was on here begging for knowledge but....here I am again, like a bad penny.
      So my 300 bayou was fine and I drive it close to 30 miles a day ( no joke, no license). I pulled over to light a cigar and drove 100 ft and started down a dip in the dirt road and it acted like it was out of gas (just filled the tank) but then when I tapped the brakes it started running fine.
      Now it'll start but runs rough unless I turn on the headlights and brake light them it'll even out and at first it'll skip and backfire almost them it'll run fine untill it goes to idle them repeat above. If I sh** off the headlights it wants to die. My boss has the same 300 so I swapped battery and cdi and regulator with his and still the same jazz. Could it be the coil? Don't they do like old cars and just die? Also went I throw my voltmeter on the battery while it's running it sits at 9.87-.99 like it's not charging, did that even with different battery, reg., Cdi. Checked the grounds, all good. It's always been a rule that if a battery has only 9 volts then turning on the lights drains power and it runs worse. I'm confused like I just saw a churchmouse kick a barn cats butt
