Similar Topics
By Jim Denton
I was gifted four King Quad 300's, they were used to tow portable snow guns around the slopes. All of the plastics are trashed and racks bent up from rolling down the mountain. The lone Quadrunner is a 98, and will be the initial point of focus, as it reportedly ran before being parked in the field of lost dreams.
By Valkman
Hey all, new to the forum. I just bought a 2001 King Quad, and the clutch is slipping. I adjusted the play with no improvement, so before I go through the trouble of replacing the clutch disc, I want to see if motor oil in it is the problem. My question is Rotella T4 ok to use? I run in my motorcycles with no issues but I thought I'd get your input.
By Wrye Pipeworks
Picked up a 2000 prairie 300 4x4. It is leaking out of the rear output seal where the driveshaft contacts to the engine. I'm havi g a really hard time finding out how to remove the driveshaft online, finding a service manual, and finding the seal on a parts diagram. Anyone know how to remove the driveshaft or know where a service manual is for it?
By Scottierisner2626
hey im new here and have been trying to repair a few different bikes but i have a 95 honda trx300 2wd and it has st
By rgeiser
so who wants to help figure out a no start on rzr 170
brought to me. brakes don't work bleeder screw snapped off caliper in rear. went to remove and bleeder ripped threads out of caliper. so i need a $300 part for that.
wont run unless WOT. fuel pump works. tried cleaning original carb. that didnt work. tried a cheapo carb that didnt work. tried fresh fuel. new plug. spark seems to be weak but everything test ok according to the manual, did valve adjustment nothing seems to help.
doesnt help that when i got it there was 4inches of mud on the motor and the cooling fan was clogged. any direction to go would be helpful thanks.
Similar Tagged Content
Gallery Images
4
1
0
0
4
5By mannyortiz7,
0
3By blahhhh,
5
2By CK1999_400ex,
0By George Henry,
0By dirtmerchant42,
4
2
4
1
4By mannyortiz7,
7By nyatvrida91,
3By mannyortiz7,
0By SeanKing,
