I also bought two  new 15 inch  trailer tires on Amazon  already mounted on rims.  BTW the Southwest wheel kit came with additional grease seals in case my Dexter axle was an older version. prompt delivery with emailed updates.   The tech support guy was nice...🫦
I wonder what brand of trailer ..aluminum trailer Mike bought?  I see the weihts of identical size aluminum trailers can vary from 600 lbs to 800 lbs.
10 hours ago, jen said:
Hard to find dealers ....They franchise through a lot of Motorcycle / ATV dealers who don't stock .
I bought this back in 2007, it is the ATV88 model from a local dealer. I guess things have changed now that dealers don't stock much anymore. Trailer has held up well. Only changed the bearings once. Been through a few sets of tires but they are small so they wear quicker.
i found a Triton w 10 inch wheels and wheels under flat 6 x 10 bed.   but it does not have triangular tongue.  I tow across country 880 miles sometimes.
Been my experience, the Smaller the Wheels/Tires the Faster they spin & are hard on wheel bearings! Bought a Used Trailer with either 8"or10 " Wheels then repacked the wheel bearings .I lost the right side wheel going thru St. Louis at about 60 mph ,the trailer wheels were probably going about 90!!
I love St Louis   and ..Cahokia Ill.  Love that area which is at the banks of the prehistoric Mississippi River.  The flats along the prehistoric river have quick sand.    A city official showed me that.
Certainly more options for ties in the 15' category. they do tow better.
Also every walmart or farm store across the usa has them on the shelf is you need one on the trip.
Nothing wrong with cheap, sounds like a nice rig, steel is good , doesnt break like aluminum, if you have a mishap. I do love aluminum though shiny no rust and pretty.very little maintenance to keep it looking good.
Gate is huge!   pressure washed it working on getting rid of my suntan lines...so   deck looks good but need to add some type of finish to it.
NICE,Looks very Good ! Use Thompson's Water Seal on the PT Decking ,works great ! Leave the Ramp as is it'll come in handy! Hope this one does what you want/need!
4 hours ago, jen said:
It's got a 4 ft gate.  I want to maybe cut it in half or eliminate it...air drag on long trips..  You Think?
Air Drag would be VERY Minimal !
Depends on the velocity of the umm   "air"  :)
Well, If trailer has the SxS on it the tail gate probably wont add any mor air drag than SxS.  If empty the gate will lay flat on trailer.   You figure?
    • By noticon75
    • By kellogs
      Hello,
      Need to buy the ATV + ramp.
      What do you guys think ?
    • By mehim
    • By logray
