Similar Topics
By sheba2012
Replaced pump and sock along with the filter still only 15 lbs of fuel pressure any ideas?
By Thegrizz
So, I just bought this quad off a acquaintance of mine… anyways, it’s missing the airbox which I’m trying to purchase if I could only figure out the year and what model of lt230 it is due to having only 9 visible digits for a vin…guy said he had the title at one point and lost it when he moved houses after the flood of 08 in Iowa….I just desperately need to know what model this thing is so I can start getting to work on it….it does run after a good carb cleaning….I’m having trouble getting it to idle though due to essentially just having a rigged up air filter with no airbox on the bike…I’ve sanded down the plastics and it looks like the original color was orange and the seat I believe is either from a different Suzuki or it’s been painted gold and black? The plastic nose part is originally black…it has the lever for reverse by the sprocket it has a pull string to start and I think originally it has electric start as well….idk I’ve had to bypass and use a screwdriver on the starter Solenoid to get it to start …someone has definitely done some rigging with the wiring as well.but if anyone has any clue what I need to look for to identify the year and actual model so I can get the right stuff. I’d appreciate it.
By Malaka
Need new tires for mostly plowing and running around. Found some good tires.
specs call for front 26-8-12 Rear 26-11-12
Has anyone put 27-9-12 & 27-11-12 as more of selections going up on front and taller
thanks all
By Oger69420
Just like the title says how do I find out what I have here I was told that it is a 1985 200 That is all I know and I need to Start looking for parts
Similar Tagged Content
- 3 replies
- 25,892 views
- 4 comments
- 2,289 views
- 6 comments
- 2,163 views
- 0 replies
- 6,187 views
- 0 replies
- 1,714 views
Gallery Images
4
1
0
0
4
5By mannyortiz7,
0
3By blahhhh,
5
2By CK1999_400ex,
0By George Henry,
0By dirtmerchant42,
4
2
4
1
4By mannyortiz7,
7By nyatvrida91,
3By mannyortiz7,
0By SeanKing,
