Similar Topics
By quadcrazy
QUADCRAZY NEEDS YOU!
By trx125flip
yay forum stuff again... really needing a 87 trx125 service manual.. if anyone has one without a dead link that would be super!
By Sha35297
So I have used the service manual to troubleshoot every sensor on this bike. Everything tests good accept the EPS Control unit. However, I do not see anything in the manual that suggests that this will cause the issue that I am having. The bike will start instantly when the button is pressed sometimes and then other times it wants to turn over forever and make a horrible knocking sound. Sometimes backfiring. After cycling the ignition it will sometimes start up right away. I have triple checked the timing and also the valve clearances. Everything checks out. The bike is for a customer that really doesn't know anything about the bike. From what I can see, the cylinder appears to be new, along with the starter. I did a compression test and it is a little high (74psi) Book says 71.7 is max. I can't see this little bit causing the problem, but I could be wrong. Last thing is that the idle is a little high. I have tried everything to get it to slow down with no avail. When I put it in gear it will jump slightly and is hard to get back into neutral due to high RPM's. Any Ideas or suggestions will be greatly appreciated.
Similar Tagged Content
Gallery Images
4By blahhhh,
1
0
2
0By SeanKing,
20
5
2By onequikkaw,
1
6By ddwyerfire,
2
7
2
1
0
1
0By StolenATV,
1By crazt4stroke,
11
4By mannyortiz7,
