all of the mount or just certain ones?
You would have to see how the motor fits in the frame. You would then find where the motor mounts on the motor are and then weld some tabs to mount that motor to the frame. I've seen plenty of people do it with the CRs so I don't know why the Yammies wouldn't work.
OK i have a 06 yfz450 motor that has a hole in the bottom end by the shifter shaft and i know 04-05 yfz has 11:9.1 comp and the 06-08 have 11:4.1 if i where to use a 04-05 bottom and and mate it with my 06 head and use my 06 piston would i get the 11:9.1 comp or would i have to use the 04-05 piston?
good question!! i think the bore, stroke and head are the same, i think it was a piston change.. not for sure tho. let me know what you find out its something besides the piston. just get an R6 motor if you have to modify motor mounts:biggrin:
i has to be something in the bottom end like the crank or piston b/c 04-05 yfz have 11:9.1 comp. with only a 439cc and the 06-08 have 11:4.1 with a 449cc. And the only thing i can think of is its either the crank or the piston
OK, im about to atempt my first rebuild i have a manual and everything i have to put a new hot rods crank in put all the new athena gaskets i bout a 05 yfz bottom end b/c my 06 is cracked puttin my 06 head on the 05 bottom end, how hard is this to do and when i split the case whats the best way to do so and will anything come flyin out at me?
Nothing should coming flying out. Lay it on it's side. It may sound like a pain but get a digital camera and take pics step by step. If you get lost anywhere you can just refer back to the photos.
So i was taking the nut off the flywheel i had the motor on its side and all of a sudden i hear something it the ground i dont know if its a bearing out of the motor or what it about 1/4 inch round and i was thinking theres noy way a bearing just feel out of this motor nothing is lose yet all the gears are still together everywhere were theres a bearing everything is still tight i dont get it and if it is a bearing i would of known i would of been able to spin the crank or anything else you can spin to move the crank, its weird
So i found out what that ball was, i was looking in the manual for once finding out what it is and the bearing looking thing is on the inside of the clutch cover theres a pin that moves on a bearing and the metal ball rest on the end of that pin
wait until it come times for the shifting mechanism, drum and shift forks...:aargh: good luck.. are you uing your 06 crank, cylinder and piston??
I got the whole engine apart,really easy if you have the smarts it isnt that hard. Ill post pics sometime soon of the engine apart and ill post more as i put everything back together
I only ran into 1 problem the bearing on the balancer one of the bearings is missing and it got chewed up in the motor i found all peices and blew them out and cleaned everything really good, im just wondering if i should get a new bearing because its only 1 small bearing that missing its like 1/4 inch long and 1/8 inch round
I got everything back together, i lined up the fly wheel and put the cams in time everyting is on all is left to do is put the clutches back in and put the clutch cover back on then bolt it back onto the bike.
I was wonder if you crank the motor using a socket and its not in time can you bend the valves if its not in time because i cranked the motor and it sounded smooth i could hear the compression.
I may have said it before but i have a 05 bottom end and a 06 hjug and head on my 06 yfz450 got everything back in and started it today it started right up but i heard a tapping noise i think its the valves they may need ajusted, the motor has a new hot rods heavey duty crank which is 1.4mm longer than the stock rod and its im time the bike rev no other.
also another problem i have now is the clutch has alot of free play when i sqeeze the clutch it goes back out some and i have push it out the rest of the way does anyone know if the clutch cable is shorter or longer on the 04-05 to the 06-08 yfz?
    • By maikytech
      Has 60 psi and motor recent flooded...what the true compretion
    • By BlueBowtie
      Is it possible to put a motor from a big bear 350 into a timberwolf? Reason I ask is that I have a timberwolf with a bit of a rod knock, and I have big bear with a bad rear end and axle with a good motor. So, is it possible?
    • By n4cer26
      Just bought a non-running 425 Magnum 6x6. Guy said previous owner had motor rebuilt (3 years ago or so.) It reportedly ran great but recently the electric start began failing and he put a new recoil on it which he broke immediately.
      I get it home and put a new recoil on it and the pull is incredibly hard....so much so that I think I'm going to break the new recoil assembly. I also installed a new starter which won't roll it over either.
      I'm thinking maybe a hydro-locked situation so I pull the plug and the motor rolls over fine with both pull start and electric start. The cylinder was dry however.
      Checked the valve lash and it was right on at .0006".
      Checked the compression relief spring on the end of the cam and the spring was strong and keeps the metal piece against the dowel like it should. The cam lobes look good from what I can see.
      I have a small camera that I dropped into the cylinder. Could t get a pic of the entire chamber because of the angled engine but there are marks on the center piston and a couple of grooves once side of the piston top. I will include the photo.
      Anyway....I'm at a total loss at this point. Not sure how to proceed and diagnose. Would sure appreciate anyone's help who might know what the heck is going on! I was able to get it to turn over about 5 times with electric start with compression tester installed which read 145 lbs. I don't know what else to do!
       Reply
      Sent from my SM-F926U using Tapatalk
    • By Jlg9969
      Does anyone have any recommendations on an engine to place into this Frame? I mean besides the OEM standard.
    • By Ejwill
      Can you buy a repair kit for the brush assembly for a gear shift motor for a 2006 Honda rancher 350es? The base plate broke where it is attached by the two screws. Broke right at each screw. All I can find is kits for the starter motor.
