Ha Ha!!!!! NICE PULL!!!!! I have the 1986 3 Wheeler Mag with the Shoot out.....
I had the Privilege of Owning Two of these New in 1985/86......My Sister in AZ still has them....
1985 Honda 250R
1986 Honda 250R
The people we used to camp with had the Tecate First Generation as well as the 86...Some also had the First Gen. Honda 250R's and the 85 and 86 Yamaha Tri-Z 250N's
The sand was NEVER the Same after that.....:yes:
Oh,,,,If any of you got the New Sept. Issue of Quad Mag......Check the Freakin KEWL article on Jimmy White......AND......The F'n Badd Arse photo's of his Race Tecate3 from back in the Day!!!! I used to Follow and watch some of these Race's.....I would love to see some Trike/Quad "Co-Ed" Racing today.....:yes:
    • By Callaway
    • By shorty
    • By sunn
      Anyone with experience on relocating the miniscule battery from the front lower center wheel area to the left rear wheel area on the Polaris Sportsman 570?
    • By mga
      My 2000 big bear 400 4x4 has 26x10x12 tires in front and 26x12x12 in the rears. Trying to find replacement tires those sizes are hard to find, or, when i do, they cost a lot more than i want to spend.
      But, there's a lot of 25" tires out there the same size, just 25" and not 26". If i got the 25" it should not make a difference....right?
    • By Need-help-with-quads
      Can anyone help me?
