Very Cool Pics.....Ive seen most of them before but its nice to Re Visit....:yes: When I have more time Ill post some of mine Ive collected over the years:wink:
Did you post them? I saw the sticky thread, but I think that's old. Just curious.
Here you go!!!!!
Here are a couple of me from 1982:wink:
My Buddy Ted Wrecking for Quad MAG:yes:
We had a Few Trikes show up at Glamis a Few yrs Back....
God,,,,That is me in the middle on my Z before I restored it....Thats also my 350X on the Right.....Draggin at a buddies Strip....I just cant belive how much I used to Weigh and that little ol Two Fitty Did some Spankin with my Xmas Ham AS*.....LMAO!!!!
  • 5 months later...
    • By roggers
      Hi everyone,
      ·        Fast to download
      ·        Cover both heavy equipment and ATV models
      ·        Clear on licensing and safety
    • By marcosphoto
      Hi folks, a little disparity brought me to this forum.  To set the stage, I'm a 35 auto tech in the industry 37 years now.  Licensed motorcycle tech also, 20+ years.  I race superbike and motocross.  Always done most of my own standard work (outside of specific race machine works) including building my own race bike engines.  Now that skills are out of the way, onwards and upwards.
      Helping a neighbor with his old quest 500, right front axle seal leak.  Well, looks like everything else - right?  Wrong!  Initially I noticed the CV joint was lacking large lands to place prybars on to pop it out, rather a thin shield like ring very close to the diff seal.  Knowing the ring appeared quite delicate, I only pried gently and the CV popped out.  However this is where things get weird.  Came out only around 7-9mm then hung up again, felt like the clip was catching inside the diff.  So spun and pulled, spun and pulled until I was blue in the face but no success getting it out.  Also while it was out, I could see that the delicate ring around the outer circumference of the joint was actually the sealing surface where the seal contacts, instead of the norm where the seal rubs inside the diff much deeper and stays cleaner.  I've never seen a joint like this, also the service manuals photos which apply to 650 also reflected a standard joint I am accustomed to rather than this one I was fighting with.  Rather than break something in the diff, I decided to stop while I was ahead and reassemble the machine before something broke.  (The joint would pop in and out of place easy enough, just wouldn't slide out further than 7-9mm).  While the joint was a little out and sealing surface exposed, I cleaned the seal and sealing surfaces clean as possible before putting back together.  Seems to be holding for now, but eventually I'm sure the leak will come back.  Any thoughts as to why that CV joint just refused to come all the way out?
    • By larryki
      best place to buy online artic cat carb and parts?
      Here is the Polaris online parts catalog, looks like you need to register with then first. I haven't used it since I'm not a Polaris owner and don't need any parts right now...
      http://parts.polarisind.com/Browse/Browse.asp
    • By loudsubz
      Where do you guys shop for oem/aftermarket parts? I'm new to the ATV scene and only purchased a few parts so far from Amazon but may need some more specific parts in the future.
