my videos
By DarkRider
By p5200
By huntindog
TIA
By vlxerdon
Hello from southeast Georgia. Was gifted a 2000 Yamaha bear tracker with out a carb or battery and looking like it had seen better days. Was told it had sat for about three years. Explained a lot. Put a carb on and a battery in and it started right up. Surprised the heck out of me Anyhow as stated in my opening I am 78 years old with a very long motorcycle backgground but brand new to atv's. Anyone else out here from Georgia? Would like to meet up with some folks for a ride or two. Looks like a great site. Thanks for having me.
Don
By Mech
View File 2022 Texron Tracker Off Road EViS service manual
2022 Texron Tracker Off Road EViS Service Manual with wiring diagrams.
Submitter Mech Submitted 11/30/2023 Category Textron Off Road UTV
