By NewToAtvs
Hello everyone, I just recently purchased an ATV for 60$ and after some research I have come to the conclusion that it is an 85 LT230. The previous owner says that it is seized and well now I have taken it apart and want to know what I should do to get it running.
By 97kingquad
By PupATV
-PupATV
By bhristianzx12
