By luckyyyyesther
Hey all!
By Bobbywolf
Thanks for any assistance.
By p5200
By opnea
Recently picked up a 1991 Lt230e for repair. Compression is a little low Id say, around 80psi, I also have spark but the spark is odd . When cranking the spark is a constant arc. I’ve got it to sputter but never fully turn on. I believe the spark is my issue, being constant and not detonating at the right time. I’m not sure whether this issue is an electrical fault like some missing ground, a faulty cdi, or a timing issue. Any ideas where I should start?
Similar Tagged Forum Content
- 4 replies
- 4,379 views
- 1 reply
- 6,187 views
- 3 replies
- 2,885 views
- 0 replies
- 4,023 views
- 7 replies
- 4,510 views
