I have been working on this quad for a buddy. When he brought it over it didnt run. Well removed the carb and cleaned well...then changed the o-rings and changed the spark plug. After all that i put it back together and hit the starter. It started up after cranking a while and ran for about 5 min. and then bogged and died. And wouldnt restart.I cranked for a while and it kinda speeds up like it gonna start but just wont. I let it set for awhile and bam it started agian..and then the same thing, after about 5 min. of running it just boggs and dies.
I did a compression check and got 125, so im ok there.
But i did notice a lot of oil on top of head. I cleaned it off and when i ran it till it died i noticed that all that oil was back. Could i have a blown head gasket?
IF you did a Compression Check and Got 125 then you dont have a Blown Gasket...It would have leaked Down...Im not Familiar with the Quads....But does it have a Vented Gas Cap???? Have you tried to run it without the Cap on??? What happens is Pressure builds up and Stops the Fuel from Flowing.....is the LT80 2 Stroke???
yes its a 2-stroke, and the gas cap might be a good idea cause the fuel petcock is ran from the vacuum of the carb. But i still dont know where all the oil is comming from.
    • By RGS
    • By RadRob
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
