Unlike motorcycle tires, ATV tire sizes are all based on the English sizing method. An example of an ATV tire size would be 25 X 10 X 12.
Tire Height
The first number indicates the height of the tire when inflated to the manufacturers' recommended pressure, in this case 25 inches from the ground to the top of the tire.
Rim Width
The second number indicates the width in inches of the rim size recommended by the manufacturer, in this case 10 inches.
Rim Diameter
The last number indicates the diameter of the rim that the tire will fit on, in this case 12 inches.
Very good pull.....Im gonna Sticky this thread for Reference and Expand upon it:yes:
10 x 8 3+5 4/110
Wheel Diameter = 10"
Wheel Width = 8"
Wheel Offset = 3" mounting centerline to inside wheel edge and 5" mounting center line to the outside wheel edge
Number of Bolt Holes = 4
Spacing of Bolt Holes = 110" (measured from center of one bolt hole across center of wheel to opposite bolt hole)
Note: Most OEM Wheel Applications have no offset (the wheel is centered over the hub). In these cases, the wheel offset is omitted from the listing.
Most of the bolt applications are in millimeters. You can determine your bolt pattern by measuring from the center of one wheel stud to the center of the opposing wheel stud across the hub.
Next, determine your correct bolt pattern. Convert your measurement from inches to millimeters by multiplying by 25.4. It's that simple.
Example:
Wheel stud measurement: 4-5/16" = (4.313")
Formula:
4.313 x 25.4 = 109.6 mm ==> 110mm bolt pattern
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
