ok thanks!! A quick question if i where to go into racing would the 450r be the best choice? Then for trail and leaserly riding does the latest one have a reverse? Thanks for your help!!
Speed_Demond
The 07-08 yfz is going to be the best one for sure. For starters I haved owned the yfz since they came off the production line in 03. Yes that is right 2003. That summer is when they started to go into production. From 03-05 the yfz had some major issues with the way they were putting oil to the crank bearings. NOT enough oil and what is happening is the crank bearing locks up or u will spin the crank bearing. This means disaster to the motor. Usually u will take out the exhaust valves along with the jug and piston along with the crank. The cost to fix this is about 1500.00 plus. So beware when you buy a 03-05 yfz. And another issue with the yfz is HIGH MAINTANANCE! have to put new rings on the piston every 30-40 hours on the motor. I have been riding 25 plus years I've had 250r honda and suzuki banshee raptor honda 450. The yfz is by far the best hands down. About the reverse, if your riding a yfz u don't need reverse just GO FOR IT !!
The newer the better, with these new high tech, high maintinence motors, you can't be sure how well the last person took care of it. If you buy a used one especially an older one, '04 or '05, you could have a very dissapointing disaster on your hands. I would by new, it's the only way to be sure. If you ride trails or cross country, get the regular or SE model, if you plan to spend alot of time on the track get the R. If you do buy used try to buy from someone you know, or buy a twostroke, less moving parts, and they cost a fraction of what it costs to rebuild a hi-po fourstroke.
Ok thanks a lot guys for all the posts. Helps me out a lot. For me I am thinking about cross country or track, but mainly cross country because I am so used to the bumps I guess lol. Thank you all again for the posts, it really does help me choose.
Speed_Demond
Ok so I might want to go with the standard YFZ and not the race one for woods racing, and if I do want to go into the MX racing get the R>
I recommend getting the standard YFZ, get some +1 A-arms, some shocks and a GT Thunder rear linkage along with a steering stabilizer. That setup would put you at 48" wide and as stable as concrete. You could use that setup for both MX and XC.
By all means, use it for racing and recreation. As long as you do frequent oil changes and oil filter clean and air filter clean it will run forever. With these 450 machines you need to change the oil about every 15-25 hours.
Ok thanks! Now if only the 08 yfz's had a tacometer I would be freaking stoked lol!! I know i will keep that air filter clean. Its hella hard on my '86 lol, go figure honda wasnt very smart way back then unlike they are now.
Who gave you that info? That would be about every other month on my quad.
JSR performance John Stallworth is the owner he is out of wichita kansas if u would like to talk to him about hours on the YFZ he would be glad to talk to u his number is 316-733-1936. He knows what he is talking about when it comes to quads very well known motor builder. he builds alot of the drag bikes that run at the little sahra in oklahoma.He works on the trx-450 and ltr450- suzuki along with all bikes.Has a big add in dirt wheels look on page 164 had my motor built by him and running strong he is not over priced about 1600.00 to do a bottom to top rebuild.
I completely understand about how much it takes to keep a 450 running strong but a new piston and rings every 30-40 hours? Break in time is 10-15 hours. There is no need to change a piston once a month. I raced 2000 miles on the same 2 stroke piston in one summer.
Wow, looks like i am going to be busy taking care of this quad when I get enough money to buy one. Thanks for all of the help guys!
You don't need to replace the piston that often. You don't change piston and rings unless you are upgrading to a higher compression piston or you are losing compression.
I did not say piston and rings I said new rings on the piston and 30-40 hours of racing is alot. One moto only last 10-15 min. How do you know how many miles you raced never have I seen a odometer on a race bike nor a dirt bike. Raced for 13 years in proam on a kx 80 and 125's my dad was all the time putting on new pistons and rings about 2 times a season.2000 miles on one motor is insane I must have been riding to hard but that is what it takes to win!!!! By the way were do u race in colorado like to check out some local tracks.
I know that I put 2000 miles on one piston because I did 2 seasons of desert racing in AZ on it. 10 races per season each race 100 miles.(That was on 2 wheels) I can see replacing rings on a race motor. Race motors rarely get broke in "properly" which would lead to needing to replace them that often.
I don't ride track so I can't help you on those. Need some trails in Co, I'm your man.
10-15 hours for break in. Keep nice CLEAN OIL in it and a CLEAN OIL FILTER along with a CLEAN AIR FILTER and your motor can last for years. I'm going strong on 2 seasons on my TRX450. The 450 motors are very sensitive so take care of it and it will take care of you.
Hey I was watching youtube and saw what the yfz can do. Im thinking about getting the 06 has anybody had a problems with this modle of the YFZ. I know i should get the newest model but i dont have that much cash lieing around. Thanks for the help
Speed_Demond
u mean either an 05 or a 06? Need to look at getting an o6 or newer or it will be trouble if u don't.The motors DON'T LAST YEARS At most 3 seasons before u need a new top end depending on your riding style and were u ride if its in the sand every other season.What I mean by top end is new rings, piston and valves. Valves alone are 300.00-550.00$ If u want a bullet proof quad get a 400 ex my cousin just got one new for 4,800 out the door at coffey county honda in kansas.
Well I just would like something that i can race with and be able to keep it going for a while. And I live at 425 feet. So once the snow level gets to about 500 feet I get snow. I am betting the engine would last a while if i took good care of it.
Any year YFZ is good if you can do a few modifications, like (for example) the oil mod for an 04'.
I asked the guys on yfzcentral (good...great place for yfz specific/tech info) about replacing pistons/rings every 15-20 hours, which I heard somewhere, and it more or less turns out to be BS. Maybe if you are a pro racer with nothing stock on your machine, but not for us average riders and racers. One dude had an 04 and his internals "have never seen the light of the outside world".
Of course, every year there are advancements that ultimately lead to better quads. I have an 07 and love it. I do routine maintenance, did a few mods, and just run the p!ss out of it.
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
