You may have folded the tire and got a pinch which led to a small hole or your bead is not set all the way. Is it both tires or just one?
It's all 4 tires, but they all leak at different levels....
if it is the bead, or even if it isn't, how can I reset them?
I wonder if while you were riding some beads of sand got caught between the rim and the tire leaving a tiny gap for the air to leak.
Take them off of the quad and put about 7-10psi and then hold them underwater. To reset the bead you might need to get the tires completely free of the bead and then clean the bead and reset with a bunch of air pressure. I recommend having it done. It is not fun to try to do them in the garage.
I think Stupidbots idea is right, my riding buddy had an issue with one of his tires leaking air slowly. after fighting with it with slime and such for awhile. He had it taken off of the rim and there was a tiny piece of a stick trapped in the bead that was causing the leak. You couldn't see it while the tire was mounted and afterward he no longer had the issue.
That sounds like it could be the problem. Maybe also use some beadsealer. You could always just grab a spray bottle of water and spray the area to see if you see any leaks.
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
