Two tall trees, a birch and a beech, are growing in the woods.
A small tree begins to grow between them, and the beech says to the birch,
'Is that a son of a beech or a son of a birch?'
The birch says he cannot tell,
but just then a woodpecker lands on the sapling.
The birch says, 'Woodpecker, you are a tree expert.
Can you tell if that is a son of a beech or a son of a birch?'
The woodpecker takes a taste of the small tree, & replies,
'It is neither a son of a beech nor a son of a birch.
It is, however, the best piece of ash I have ever poked my pecker into.'
    • By kiriyaaoi
    • By afa913
      Do the small 50cc's have a way to set the speed. Im wanting to get one for my kid and i need to set it to go slow. I know the chinese knock off fourwheelers do but i dont really want one of those
    • By RepairmanJake86
      I own my own business and have grown immensely, I do good work and want to guarantee it for a reasonable amount of time. Any business owners out there guarantee your work for a certain amount of time? How long is reasonable in your opinions?
    • By Charlesawest936
      Hey guys iv kinda gotten myself into a pickle here and hopefully someone that really knows about these kodiaks will chim in please. Anyways whats going on is iv got a Kodiak 450 that was stuck in gear when i bought the bike. Stuck in gear meaning that the transmission was locked up. The motor still ran good it just wouldnt move. So i pulled the engine and split the case and found that 3 gears had teeth broken off of them. And might i add, the metal that these gears are made of is complete trash! Well at least the metal that my original gears are made of are but the gear-set that i ordered the metal looks to be made of a completely different material. Not sure if this is the correct word for it but i wanna say "Pot metal" is what im thinking iv heard that be called before it has like air bubbles throughout the whole thing it looks like. Anyways my issue is that the gearset that i ordered looks almost identical all except 2 of the gears the ones that the chain goes on which drives the output shaft that runs the middle drive gear so i found a chain thats supposed to be for a kodiak 400 since those are what gears i bought that didnt come with the chain. I was just assuming that the good chain that i had was going to fit the new gears. Does anyone know anything about the transmissions in these bikes that wouldnt mind helping me out? The 400 chain should be here in the next couple days when i get it ill let yall know if it ended up fitting the gears i have or not
    • By Sonders
      Hey all, I recently bought an 01' Sportsman 500 HO from my brother in-law that he's had since new.  It runs awesome, just has 2 slight issues that I am addressing.  1st issue is fuel dripping out of overflow.  I did some searching around and saw that the O-rings in the carb wear out and allow fuel to leak, so I replaced both the Orings inside the carb.  This didn't fix it and still leaking which leads me to believe the float needs adjusted, I'm just not sure on correct way to check and correct this.  2nd issue is no speedometer.  Also in researching this it appears to be Hall Effect/speed sensor.  I'll be ordering one of those to replace, which sounds like a pretty straight forward process.  I guess really my only reason for the post is to get some help on the gas leak issue.  Any thoughts?  Other than that, I love the bike and really enjoy riding it.  Thanks in advance for any replies.
