Love Tats!!! I looked at several yesterday on the Beach....Both of those look Great....However,,,,I have many Names for the Fish....LMAO!!!! Can anyone Guess any:wink:
I have also been thinking about getting another one....Just finding someone that I like is the Hurdle....Were these something you guys picked off of a Wall or something you Designed????
I knew I wanted a Koi so the artist drew up my design. For her Nautical star, we just like the stars. I have a star and my right forearm and the koi on my left. The Nautical Stars are supposed to bring you luck and get you home safely from journeys. The Koi is a Japanese symbol for power, pride, and "mystical powers".
We wanted some kind of matching tatts without them being identical or each others name.
Other than Carp or Koi, I don't see where you are going with this so I'll bite.
The Nautical star on my left forearm brings "good luck and a safe return home"(started with sailors)
My initials on my back.
Right shoulder has the Chinese symbol for "opportunity"
My right calf has a crying sun setting on the ocean. I got that the day I left California.
And the Koi is the Japanese symbol for the strength and ferocity of a dragon. Along with nobility.
I have a couple of Tats on my Left and Right Shoulder...My Buddy did them in High School with just a Sewing Needle, Thread and Indian Ink...Total of 27 Hrs just pecking away...LOL.....We were going to do a Whole Scene with all the characters Partying...but he Died before we could get it done....Ive thought about haveing someone Else finish them but just never have....
I also want this somewhere
Edited by mywifeknowseverythin
  • 7 months later...
well I havnt done a tat on myself in yrs but I do them on everyone else all the time so if ya'll dont mind me showin the ink I done recently
this was a cover-up
this was also a cover-up
thats awsome work...yea we'll have to hook up some time that would be cool I have some fam that lives in riverside cali,and sandemas me and the wife have been talkin about going up there to visit maybe next yr around this time.but yea I wouldnt mind doin some ink out there
the cover-ups where of some old things she very first had gotten done when she was a teen here are some pics of before so you can see but I only have before pic of the tat with the rose with water swirl the other I guess I forgot to take S7300454.jpgS7300455.jpg
also here is the newest tat I just got done doing
    • By HoldenBoy
    • By 86096
      I have a 1985 Suzuki LT230 GE quadrunner.  It has been stored in a shed for at least the last 15 years and has very low mileage.  Although the tires look and feel great... should I consider changing them since they are 38 years old?  I don't intend to ride to far or too fast but I don't want to have to walk out of the bush.  Any input would be welcome.
    • By Jd101506
      Hi all!
      I've got a 1988 LT4WD that I am working on.  It sat for almost two decades in a shed, so I replaced both the carb and the fuel pump (Pump was rusty, carb was ok, but had a pin hole in the bowl itself?).  Now, I went el cheapo and I replaced BOTH with Chinese aftermarket Carb and Fuel pump.  Now is where it gets confusing:
      So I did this SAME thing on my other Quad, a 1988 LT300E.  They take the same PN carb, and a similar fuel pump, (One has a 90 degree bend in the vacuum port).  I've been battling the four wheeler a bit with some electrical issues, but I noticed that at idle it runs GREAT when I gravity feed fuel from a burp can into the fuel bowl of the carb... But as soon as I put it on the fuel pump from the tank, it idles EXTREMELY low and smokes a little.  To me, this indicated that the carb itself was running rich.  I adjusted it a little on the LT300e, but I could never seem to get it right, it still will slowly die at idle when warm, but ironically if I CHOKE the motor, it'll start up and run.  I dont know if this is because the RPM increases?  But the quad will run around the yard great at RPM and then die at idle.
      Now, the LT4WD.  I ended up with a faulty fuel pump for my second (I think the spring isn't seated inside as I can hear one rattling around) so when I installed it it WOULD NOT pump fuel.  So I ended up swapping the LT300 pump onto the LT4WD.  Boom, pumps fuel.  I put it all back together and got my tires on.  I ran it around my yard and it exhibits the SAME symptoms as the LT300e!  It will run around at RPM, but it will not stay running at idle, it drops realllllly low RPM and will start smoking a little as if its running rich.  Again, when I ran it with the fuel pump OFF I didn't have this issue.
      In my head I'm thinking it would be a mixture screw OR float issue... But the mixture screw doesn't seem to help me on either, and the bowls are not over flowing (I checked both overflow lines).  Is there something I'm missing here thats obvious?  Is there a vacuum line or something I missed? Maybe some configuration or something I missed? I reviewed the manual and nothing stood out to me.
      Conclusion:  Two different Suzuki fourwheelers, two different carbs (Both are chinese Ebay carbs) that BOTH run well when I mainline fuel from a drip can INTO the bowls, BOTH do not keep idle and seem to run extremely rich as they run great at RPM but slowly die at idle.  Adjustment screws, idle screws be damned.
      I ended up ordering a new Suzuki OEM fuel pump for ~90$ just to have it and see if it makes a difference.  Any advice here though would be SUPER appreciated!
    • By 8AV8
      I just purchased a 2004 Polaris Sportsman 700 EFI. While riding today I noticed the throttle lever
      was getting hot, not just warm but too hot to touch. I’ve never encountered a problem like this before.
      I have a service annual ordered but it won’t be here for a few days.
      Any help would be greatly appreciated.
    • By WyattLemke25
      Having problems with the battery draining while riding. It has a new battery, it does have eps, a lightbar and a winch. Can ride it for an hour or more just fine, but eventually the battery runs down to the point it can't keep up with fuel injection and it'll sputter, limp, and die. It also throws codes for the throttle position sensor. I'm not sure if that is related or not. Any ideas?
