I'm sure you have all wondered about snorkels on your ATV and I have finally went for it and made dual snorkels for my ATV.
My quad, like most, comes with a factory snorkel So I removed that and put some 1.5" PVC out of it with two 45 degrees to get around the engine like so:
Then I continued off of that with a straight piece going by the engine and into the fender
then in the fender I used 3 90 degrees to clear make sure the wheel never rubs on it.
I dont have a good pic but I used a T pipe at the top part to split it into a dual snorkel (I had a single but the dual made a difference by giving it all the airflow it needed)
Here is a picture of the whole assembly if you are having trouble visualizing it
After all that I painted the PVC black then used clear tubing (refrigerator water line) to extend the factory vent lines from the rear drum and differential. This is very important...
here are some finished pictures (I dont have any from the OHV park but they have passed the creak test :D)
Edited by Spooge
hey its been a while... atv has changed a lot i see u got a k&n and some itps in the rear...if ur going to go through some deep stuff, switch out those mudlites for some highlifter outlaws...o and with that snorkel u didnt have to rejet? anyway great job.. and did u put di-electric grease on all your electric connections??
Im plenty happy with my mudlites especially with the mixed terrain I ride on.. and I didnt modify the engine at all for the snorkels.
And yes, before winter I greased all of the connections... funny story, before I got the mudlites I got stuck in deep water and my winch was able to pull me 20 feet to the shore... while completely submerged!
  • 6 months later...
Sweet snorkel setup. I was wondering how easy it would be to do this. Is it recommended that you also do the vent lines when you do this? I saw yours attached to the snorkels.
Thanks!
I was able to make and install these snorkels in one day so its not a very difficult project and yes you do want to extend your vent lines so you dont get water in your brakes (first line) or in your differential (second line) and mixed in with the diff fluid
Very nice set up...do you have any pictures of your quad submerged?
the last thing I wanted to do was snap pictures in that situation hahaha, but I did take a pic after I got home...
    • By colin james
      View File 2017-2019 sportsman 450/570 with eps factory service manual
      This  is the factory service manual for the 2017-2019 factory service manual for the sportsman 450/570 with electronic power steering
      Submitter colin james Submitted 09/06/2018 Category Polaris ATV
    • By Sha35297
      I have this bike in my shop for a customer. It was sunk completely under water and left running until it killed. I did a complete engine rebuild. Replaced all bearings, crank, oil pump, and various other components. Engine starts and runs great. It will shift up through all gears perfectly in automatic and in ESP, but when slowing down it gets to 3rd gear and the MIL "-" light comes on and stays on. No flashes or anything and it will not shift gears. Kill the engine and restart in ESP mode and it is able to shift to neutral and start over. Does the same thing while down shifting in ESP mode. I replaced shift angle sensor with no improvement. Checked oil pressures as per repair manual "74psi" and higher with higher RPM's. With no MIL codes to point at an issue. I am at a loss as to what else to check or replace. Has anyone else ran across this issue?
    • By killerklown
      What's the proper diameter recoil rope to order for a Bayou 220? I didn't see anything in the manual.
    • By Sycoholic
      My son got his Tri-Z finished. Full resto mod. Polished a lot of parts and even used heat shrink clamps on the hoses. Lots of cool little attention to detail. First official ride not around my house was at Horsepower Park in Morganton, NC (the old Antioch Speedway). The track was a bit rutted from the recent rain/flood we've experienced but still was able to fly through turns 3-4. This thing is a blast!
      Daniel Z rip.mp4
      For years I've been wanting to get my rowboat back out on the reservoir here in lower NY, just never found the time and every year came and went. Its NYS watershed and NYC water supply so you have to have it registered, tagged, and cleaned before getting a spot on one of these. Now I just need to dedicate some time to get out there and fish! You end up leaving it chained to a tree and it stays out there for 3 years before renewing it again.
