hey, i'm rhonda. i ride an 05 trx450r. heres a picture of my quad, one of me, and one of my son and husband--dont have any of me on my quad in my pc apparently. i just need something to do to pass some down time at work... i am 23, married, and a mommy of a 2monther.
Im Zach, Im the fat dude in the pic. Rhonda rips, shes had a few good crashes too, she once jumped her vespa scooter about 40ft. Shes an animal and she'll ride all day through the desert and not even nag me about it.
Heres my quad, I used to race until I broke my back a while ago.
    • By Cohen9966
      Looking for something similar for my 2018 Sportsman – this helps.
    • By Tjp5093
      I'm working on my 02 Honda forman 400 and I have the side case off. I'm trying to see a picture of how the clutch fork and clutch arm on the end of the shifter shaft line up and what direction to face the triangle bearing with the spring.TIA!!!
    • By QuadConfussion
      Hey everyone! Just introducing myself and hoping I can get some insight on where to start. I have an older quad, my guess is about an 07. I know it’s a 700 but I’m having some stalling issues with it after it runs for about ten minutes it will die out. It will start right back up and run but after a minute or two it will die again. Any suggestions on where to start checking things?
    • By Spartacus Stroppel
      So I have a 2001 Kawasaki prairie 300 I could not find tough country snow plow... it's a older plow too boot... so I made the plow mount and updated the plow with some skids.
      Mount plate is 1/4 steel plate and so are the pin points
      The skids are off a moose plow. I got some plumbing black pipe for holders to weld to the blade and braced it with pieces left over from the plow mount 1/4 steel...
      1/4 plate cost $45
      Skids cost $24
      U bolts and other hardware where $20
      I got the blade free
    • By HeWasRidinDirty
      Hey all. I got a stripped hub on this 450r ,and I ordered some new oem spec hubs, but they don't fit on the splines. I can't find and I.D or a name at all on the axle. The splines measure right around 28 mm. They're a good bit bigger than the stock ones. I even tried the hub from a 700 Raptor, but no-go.
