Hello All,
I am in need of a little professional help. I have a 1993 350l. The other day It was running great. I took it for a ride around the house and pulled back into the garage. This is when it all happened. It was idling fine for a few min when all of a sudden it back fired (sounded like a shot gun going off) I could not get it started. I left it for several days and tried to start again with no luck. The only way I could get it to even pop was to spray starting fluid in the carb. I figured it was a carb issue so I rebuilt it again with no luck. Tore top of engine down to discover a hair line crack in the bottom of the piston skirt. Rebuilt top end with a wiseco piston. Had it bored and matched to the new piston .5mm over. I have great compression 125psi. However the engine will still not start same simptoms. Is it possible that when the engine back fired it took out a crank seal? What else could be the issue. I have good spark, fuel, and compression.
Thank you
Check the flywheel key, if it has sheared off, you can still have spark, but not at the right time. I suppose that the backfire blowing a crank seal out is feasable, it wouldn't hurt to check them.
I removed the flywheel to replace the seal and all looked great, no issues seen. I am waiting on a clutch puller so I can remove the clutch and replace the seal on that side. Can anything else cause this issue?
It really sounds like a timing issue, but I think that the crank seals would be a good place to start, since they aren't too expensive. I had alot of hard starting that was cured when I replaced the crank seals. If the motor is sucking air in through the crank seals, it won't draw fuel in as well. However it should still show some life when you use starting fluid. Try pulling the plug and spray the starting fluid directly into the cylinder. What does the plug look like? Is it really oily? Another thought, if it has been sitting for a while, some gummed up fuel could have plugged up the carb while you were riding.
I have been able to get it to sputter with starting fluid, the carb was completely rebuilt after this first started. Thats what I originally thought it was. When I pulled the flywheel and stator off, it all looked good, I didnt see where anything had moved or was loose. I am currently waiting on a seal and gasket kit to come in, I plan on replacing all crank seals (besides inner dont want to split cases) and the water pump seals and gaskets while I am in it. Please if anyone has any other ideas let me know. I will post the final outcome.
New crank seals are a good idea at any time since it can't hurt to replace them. If you find the problem before you install the new seals, then you will have them if you ever need them. I would test your igniton components ie; stator, pickup, cdi, coil, spark plug and make sure you have a good connection between the coil wire and the plug boot. You may have spark, but it may not be strong enough. Do you have a manual? It would have info needed to do the tests on your ignition components. If you can get it to run, check the timing. Maybe even try adjusting the timing a little just to see if it helpls get it started.
Thanks guys for all the responses. I haven't been able to get back to working on the bike. My new seals came in on Friday. I plan on working on it Tuesday. I will try the seals as I have already pulled old seals. If that doesn't work I will try the other things you all have suggested.
Thank you!
Ok, The wheeler is running like a top. Once I removed the clutch, I found the crank seal blown out. I bought a bottom end seal and gasket set and replaced all. Now the bad news, while doing so I broke the temp sensor on the head. Does anyone know where I can get one of these and is this the sensor that turns on the fan for the radiator? I ran the engine for about 5 minutes but the fan never turned on so I shut it off. I do not want to burn the engine up after all the work I have done. What is the temp the engine should run at when the fan turns on?
Thanks to all, my machine is up and running. I have had it out several times in the last few days. Cant wait to burn through the tank of double oil and its broke in. So far the thing runs flawlessly.
    • By middlebrookgt
    • By 97kingquad
    • By maxbeg
      hey guys, I just bought a bayou 220 1989 and it doesn't start manual and electronic, keep blowing the fuse on the starter coil 20 amp when I plug the battery, ignition is not even on.
      I removed the body to make myself some space to see the wires, they are not that bad. The only thing that I found is the relay assembly is rusted on the top, like water infiltration in the relay.
      lets me know if you ever have experienced this problem or you have solutions for them.
    • By Freedomflyer
      MGoing to apologize in advance to those that have a soft spot for wolves. They are definitely not my favorite species of animal.  They continue to grow bolder and bolder even with the population exploding all around us in this wide open valley floor. This valley is approximately 40 miles long by 35 miles wide. Was once mostly agricultural but over the last 25+ years, the kids of long time property owners have sold to the highest bidder.  Developers buying up small farms and ranches for millions of dollars and eating away at the local agricultural way of life, destroying the rural Montana I, and many natives, once knew, covering up perfect farm land with urban sprawl, never again to produce a grain of wheat or barley,  potato,  canola seed, or any crop of any kind ever  again.  Lining developers pockets, raping and pillaging another rural area and leaving the infrastructure in a colossal mess and the local cities trying to figure out how to pay for the improvements to move the traffic, overloading an already overloaded tax base.
      FINALLY, after years of farmers and ranchers lobbying and legislation, they finally opened up a season to hunt the destructive and devastating consequences of the reintroduction of wolves into Yellowstone National Park. These animals have become a huge problem outside of the park boundary. Did the powers that be actually think these killing machines would stay inside the park boundaries? Really? Hmmmmm, not the sharpest tools in the shed. Their population has exploded over their reintroduction into the park in 1995. They released 41 wolves into different areas in Yellowstone Park, then made it illegal to kill any of them that came out of the park boundaries. Pretty much leaving farmers and ranchers defenseless in protecting their livelihood without becoming a criminal. If they did ever shoot one the investigation process has been so stringent and stressful a lot of them have done the 3 S's. Shoot, Shovel, and Shutup! There are now over 1500 wolves in western Montana, over 1100 in Idaho, over 400 in Wyoming, and almost 150 in Eastern Washington. Who knows how many have migrated back into Canada.
      They finally delisted the wolves and opened up a hunting season on them, something that should have been done years ago before they decimated our elk population.
      A friend of ours was able procure a tag and was able to fill it yesterday morning. The wolf was down in the middle of the valley floor stalking his cattle on his family ranch, definitely deserved to be taken out. Personally would like to see more taken down, they have gone well beyond repopulation with this program and have spent millions on tracking and thousands of man hours, colossal waste. Glad to see another one gone.
