Hello everyone, this is my first post to the forum. I have a Honda Fourtrax that will not start when you push the start button. no kick start. However it will start if you jump across the two posts on the sylenoid. thus far i only sprayed wd40 into the start and kill switches. any suggestions?
My guess is that it is either the start button itself, the wiring that goes to and from it, or the solenoid is not working anymore. I would start at the solenoid, if you have power at the low current feed wire (the small one) on the solenoid when you push the start button, the solenoid is your problem. If not, I would start at the battery and trace back toward the solenoid and see where you lose power, that will be where you find the problem.
I had the same problem with my 300EX. I bought a brand new solenoid and that did nothing. After that I pulled the starter off and cleaned it out (I had a bad O-ring on the starter, so water had got in). Has worked perfectly ever since.
  • 10 years later...
I have a 1996 honda fourtrax 300  it has a starting problem it wont start in neutral while its sitting there but if i slightly pick up on the gear shifter then it starts and sometimes it takes a few times doing this to get it to start
  • 10 months later...
Does the solenoid clock when you push the starter button? If so, then the starter motor is the problem, plenty of new ones on eBay.
If no click then it’s either the solenoid or the starter button or wiring between the button and solenoid.
    • By realpilot
    • By Cj Winds
    • By OldATVowner
