:huh:i need to split the right side of the case according to the yamaha dealership to make sure i have no dirt or anything in the engine before i put my cylinder back on since i got it bored over. do i have to worry about anything just falling out it i just pull it off. someone told me to get a pressure washer and soap and spray the hell out of it and itll take any dirt or anything out. will it hurt anything or what is your ideas on the subject thank yall.
yea a lot of things will fall out wen u split the case. wen they said use a pressure washer were they referring to washing the outside or the inside? the inside you can not wash with water. that willl do a lot of damage especially if it is pressurized
a couple people said to split the case and go to the car wash and spray the inside of the motor. i figure that would mess somethin up. what should i do. i split the case and started messin around kinda lookin for dirt but didnt really see or pick none up. only one thing fell out when i took it apart but that was easy to put back in.
I wouldn't use a pressure washer on the inside, that is like using a sledgehammer to drive finnishing nails. Since it is most likely pretty clean in there. You just need to make sure there aren't any pieces of dirt or metal shavings floating around in there. A regular hose sprayer will be fine, just make sure to remove any loose fitting parts so you don't lose them. Otherwise, I would leave the bearings in there unless they need to be replaced. The water wont hurt them, just blow everything out with compressed air when you are done and let it dry. Then apply a coat of oil to everything before you start putting it back together. Very impoprtant that you make sure everythign is in the right place, even something as small as switching two very similar washers around can keep things from operating properly or operating at all for that matter. Also very important to make sure all gasket sealing surfaces are clean, flat and have no gouges in them.
    • By fwsamm
