By 86ccord
By HSTAR
By ResQ91
Hi guys
battery and connections good
By John Sinclair
I WANTED TO UPGRADE THE CARBURATOR ON MY 1992 BIG BEAR 350, SO I ORDERED A NEW CARB FROM EBAY. ACCORDING TO THE WRITE-UP IT WAS A GOOD FIT FOR BIG BEARS FROM 1988 TO 1996. WHEN I REMOVED MY ORIGINAL CARB I NOTICED THAT IT WAS DIFFERENT FROM THE NEW CARB MY CARB HAD TWO THROTTLE CABLES THE NEW CARB ONLY HAD ONE CABLE. HOW CAN I MAKE THIS CARB WORK ON MY TWO CABLE THROTTLE? -
By ResQ91
Hi Guys!
Or ??
Dave
