Start looking for visual signs of wear from parts rubbing against each other. I would start in the transmission, but it could be anywhere in the drive train. If it is making that much noise, it is quite possible you will be able to see the problem when you find it. Hopefully someone with a similar machine may have some more detailed ideas for you.
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By carkivey3
