Challenge
By pastorjeep
Need a little help fixing a no spark issue. 2002 BT with the 2 wire ignition switch. I have 4 stators and 2 CDI's and 3 coils to test. The new stator reads 218 ohm, and .2 ohm, the one that came out of it reads 50K and .2, the other is 132 and .2. All of the coils are 0.00 ohm, and there is no way to test the CDI that I know. I have also confirmed the replacement stator pins match the factory locations. I did try to test milli-volts at the coil to see if it was getting any signal from the CDI but nope. IDEAS?
By lester
I picked up a 2000 Big Bear 400 4X4 that was sitting around that I know nothing about. It will not start. I do have a red light when in reverse. When I take it out of reverse, I do not get a green neutral light, and when I push the start button the red oil light comes on but there are no noises, nothing else happens. How do I test the neutral switch and/or bypass it to see if I can get it to at least crank? And does anyone have other suggestions for me to try?
By lewisrssll
View File How To Perform Compression Test
How to perform compresion test
Submitter lewisrssll Submitted 10/06/2024 Category Other ATV
By JPRICE1981
Hello everyone !! Looking for some help !! Im wanting to check my stator and pick up coil with a ohm meter and cant seem to find a guide that tells me what to read and what my reading should be !! Any help would be great !! THANKS IN ADVANCE !!
By VikingTrad3r
I have an 86 yfm250 (moto4 250) i picked up.
It bogs and pops a bit out the tailpipe if you can even get it higher up in the rpm. It is pretty gutless. I have other 250’s (timberwolves) and its ultra gutless compared to them.
It has an aftermarket carb on it that has a “W” on it Its not a mikuni but it looks close
i figured jetting was off at the high end.
i had a mimuni that was very crusty, swapped the main jet into the W carb, and the needle, which was set on low slot 4 so left it there.
it actually ran much better, and cured what i thought was a problem caused by a lean condition from the W carbs main jet being too restricted when i compared to the factory mikuni
I had it out and was enjoying the upper rpms that i couldnt reach before without bog. at wot it would fall on its face low top speed.
after getting it hot, it would actually refuse to start after dying.
back to the drawing board.
when i first got it i adjusted the valves. So i retraced my work and thought maybe id overtightened. double checked, nope all good. .005 exh , .003 intake, check.
So i checked the compression.
here is the trickyness. help me understand this. I am at 3500ft asl in calgary canada
- initiate test, it goes to 75psi right away. this is low. Even at my elevation im thinking 110psi minimum
but....this thing starts no problem. even -20c it starts. makes no sense to me. so i press the starter again and it goes to 85. Then i press it again and no change. Then i turn over again and it jumps to 95. Then again...no change. Then again and it goes to 115. finally finishes at 120 and i cannot get it to go any higher than this.
ive repeated this multiple times.
i press and hold the starter...it will max at 75. Then a series of maybe 10 more quick turnovers from the starter and compression inches up to 120psi.
So, i think the low compression explains the low top end, and even the backfiring out the exhaust when hot. The exhaust is rich enough (incomplete combustion in chamber) and to ignite in the muffler.
it gets worse when hotter.
makes me think i have a crack, or something that is low down on the cylinder wall. When the piston stops just above it on the upstroke, and i then turn it over again, it adds pressure to my tester reading.
thoughts?
