I rode pretty hard 2 different times while I was in Indiana. I could not get to a power washer before jumping back on the highway. Im back in Atlanta & my Grizzly is still sitting in the garage, as filthy as the day I drove it. Will it be ok if I dont have time to spray it off until later next week?
I've kept my quads muddey for weeks at a time, especially in the winter when the stuff freezes on there. I've had to soak it down with hot water to get the mud off..on occassion. Should be fine though.
Storing a machine dirty for a while wont really do any harm. Never cleaning it is different. Dirt is abrasive, so any moving parts will wear prematurely if they are always dirty. I am not real big on washing my machines to a shine, in fact, they always look dirty. However, I do like to give them a good hosing after riding to knock most of the dirt off the machine and then I lube everything.
Edited by DirtDemon
    • By HoldenBoy
      Hi all,
    • By Adamb2025
    • By middlebrookgt
    • By Louznmemind
      (Question is at the end if you want to skip my blabbering) I got this unbelievably well taken care of Grizzly 350 in for a carb clean, it belongs to an elderly couple that bought it brand new in '07. Apparently whoever has been doing their oil changes for them never checked the air filter..
      Obviously it got debris in the carb, it would still run but only idle with slight choke. I've taken it apart and cleaned it, have new o rings, gaskets, etc. As far as the mixture screw is concerned, I'm assuming I obviously need to remove the plug. I'm mainly a lawn equipment guy, I've worked on slide carbs in the past but never an unmolested one with the plug still intact. I hate to mess with it as the carb had very little debris but I'm sure the o ring needs to be replaced at minimum. Finally, the question: what's the best way of removing the plug? I DO NOT want to mess up this carb..
    • By Louznmemind
      Can someone please tell me the fill point on the drive axle? '07 Grizzly 350, straight rear drive, not independent. Thanks
