Please post the year of your machine. Do you have the cover off? There is a cover bolted on over the brake drum. If so, does the drum wiggle at all, or is it completely stuck? Make sure the brakes are completely released, you may try loosening the adjustment screws all the way. Also, there may be a dampener ring in the drum that is hanging up on the shoes. You may find a service manual to be of great help as well.
yes i have the cover off and the brake is released. I see that its on the splines of the shaft is there a puller that i need looks like its just froze. the bike looks to be a 95 fourtrax 300 4x4.
* Adjusted your thread title to include year and make, also issue.
Sometimes you need to use a hammer and give it a couple of good hits toward the center on the front of the drum, to free it off the spline, otherwise you may just have a seized bearing race and will need a small brake pulller that you can probably get at an autoparts store or Sears. If that's teh case, you will need to replace the bearing.
Actually, I'm not 100% sure on that model if the bearing is inside the drum or in a hub assembly...:confused:
    • By vaneleus
    • By Olchap
      Thank you,
      Olchap
    • By RussB
      Has anyone found a rebuild kit or an aftermarket replacement for the original which costs 500.00 US dollars?
    • By Rickm59
      I have a 2022 Kymco MXU150 and have been trying to bleed the rear brakes for several days. I have used a vacuum and also tried the lever pumping. i took the caliper off and compressed the piston with a C clamp and had a tight brake lever. I put it back together and still cannot build any pressure in the brake system. Any ideas from anyone?  Thank you
