Hello All,
I'm new to this Forum! I have read all the rest of the posting pertaining to the display screen, I do have similar issues and I need all of your help!
First off the atv starts and runs fine but when I turn the key on the display flashes until I push the "select" button, then everything is normal on the display. When I start riding the screen starts flashing again.
I have checked the connections (used connection cleaner), charged the battery to full, unhooked the battery over night, but it still flashes and does the same thing.
Things I still have to try:
- changing the gas and putting fresh gas in it
- changing the spark plug
- checking the belt (not sure if it’s the correct one or not but it runs fine)
Is there anything else that I have missed?
Does anyone have a PDF of the owner’s manual?
Thanks for your advice!
I don't really know what to suggest about your problem, but I have noticed that there is more than one person here who has posted about the same problem with the same exact machine.
http://www.quadcrazy.com/atvforum/arctic-cat-atv-forum/7477-2007-arctic-cat-700-efi-wont-run.html
http://www.quadcrazy.com/atvforum/arctic-cat-atv-forum/7343-2007-arctic-cat-700-efi-4x4-digital-display-not-working.html
Edited by DirtDemon
artic cat has alot of problems with there displays
pin point issue by replacing display with known good one
this will allow you to tell if its a wiring problem or a switch power issue
aiticat had issues with wiring
i just remember having a problem like that from a new unit
turned out to be temp sensor wire shorting to ground as i was
replacing harness
    • By RadRob
