my 2002 400ex just wont start but wants to
01 RAPPY 660
i just got a 2002 400ex and..................
when i try to start it, it tries to start and stops tries to start and stops tries to start and stops over and over, like it has the hiccups, but wont start and run. the carb is clean and it's getting gas to the engine, the spark plug is sparking a blue spark when i hold the plug to the frame. ive put a new timing chain and stock cam shaft in it, and set the timing, and it has a new piston. anybody know the problem??
:aargh::aargh::aargh::aargh::aargh::aargh::aargh:
thanks
The compression release is on the cam, and it sounds like it isn't working. It should bump a valve open as the starter turns the engine over to release some of the compression in the cylinder. If it isn't working, the starter will have a hard time turning the motor over and it will make bad noises when it is trying to start.
That sounds very similar to what my friends 450R was doing when he broke his decompression pin in his cam. It would turn over, but it would kind of "hiccup" and sounded like it was kicking back and stopped. It did not sound pretty when he tried to start it, so we just started taking it apart and found the broken pin. Since we were already in there, he ordered the new decompression cam and pin along with a stage 1 Hotcam. Is your machine still in the shop? If so, any word from them? Are you completely sure you had the timing chain on right?, the marks on the cam sprocket line up and you are sure the crank is at TDC when you lined them up?
Edited by DirtDemon
oops
Take it back and take it somewhere else, do not give them a dime, because they are incompetent. They should have this fixed by now. The only thing that makes any sense to me is the decompression mechanism. If it isn't working at all, it will not release compression and the motor will have a hard time turning over. More importantly, if it doesn't stop working like it is supposed to when the motor starts, it would be just like a stuck valve. Since they were suspecting a stuck valve, maybe they need to take a look at the decompression mechanisme again.
i stopped by today at there shop and there saying the cam shaft is bad, i remembered you saying the compression release mechanism on the cam shaft is not working, so the -BRAIN DEAD- mechanics there to check it out. and it's pretty damn bad it's been 3 full weeks and there steal dicking around with it!
THANKS AGAIN D.D
Yes, 3 weeeks is ridiculous, they are supposed to be professionals. It should have been fairly obvious if the cam was the problem. Make sure they don't sell you more than you need. If the cam is bad, then replace just the cam, I would suggest upgrading to a stage 1 hotcam if it needs to be replaced. If it is just part of the decomression mechansism that is not working properly, don't let them try and sell you a whole camshaft assembly with it. It may just be the spring for the decompression cam that sits on the actual camshaft. Ask to see the defective part, or parts before you authorize these morons to do anything. I still think it may be in your best interest to take it elsewhere, if it took them this long to find the problem, do you trust them to be able to fix it properly? What ever you do, I hope you get your quad back and running soon.
thanks again D.D
it's sad there a business and they do shity work like this! they always call and ask before they do anything to fix it so ill know whats going on, and im going to go there monday and check out what there saying and go from there.
the place is........... Greenfield motor sports in Indiana, they have a website also.
Got $5 that says it's a problem with the compression release. Would have suggested that earlier, but I did not catch this thread until the day that Bansheeboy posted that he had already sent it to the shop.
You are welcome, we are here to help. I believe someone owes me $5, and I think that it is Greenfield Motorsports. Glad to hear that you have finally gotten it figured out, I hope you are riding it again sooner than later. BTW, if those guys need any future help diagnosing problems, refer them to Quadcrazy.com
Edited by DirtDemon
well the compression release on the cam shaft is rebuildable so im having it rebuilt because my cam shaft is fine rather then that.
and LOL im thanking about it D.D
thanks again
jeremy
well i FINALLY got my quad back BUT........ theres still a problem... it will start and run and rev but it's acting like its being choked, ive cleaned ALL of the carbraters gas and air passages/ports and i cleaned the old air filter but it did not help. it wont idle unless you are giving it some throttle and then it's semi smooth idle when it dose idle. i drilled the pilot jet out because it was very clogged but i did not see much if any brass shavings come out so i dont see that being a problem. as far as the main jet im not sure if its right on where it needs to be set, when i took it out to clean it, i had moved the adjusting nut on the main jet. i put the main jet back in the way tight and it stops, then i tightened the nut up until it's tight so i dont know if thats where it needs to be.
THANKS AGAIN
JEREMY
Edited by yamahabansheeboy
The main jet should me screwed in until it is snug, so it sounds like you have it right. I would first try adjusting the pilot screw, it should be on the underside of the carb, in front of the float bowl. Start by turning it all the way in and then back it out 2 turns. See how it works and try adjusting it back and forth to see if there is any improvement. You will also want to make sure the float bowl vent line is not clogged. The tube for it comes right out of the bottom of the float bowl, make sure you can blow air through this line.
    • By Spritee1
      not sure where to look next
    • By hardcastle
    • By McG75
    • By mehim
      Hi everyone.
    • By ResQ91
      Hi Guys!
      Or ??
      Dave
