By tepin
By spigmef
I bought a 2008 arctic at 366 with 120hrs. When i red line it in neutral is smokes blue a lot. When I put it in high range it has problems getting over 35km/h. I bought it and had to clean the carb. It ran ok after i cleaned it. Not I have this problem.
By 97kingquad
By ath1981
Got a 2011 425 EFI. It eat 2 belts, so I replaced the drive clutch assy, rollers, spacer and movable face. Put on a new belt and after 30 min of riding, it eat another belt. any clue what can be causing this?
