hi all,, when im on my atv and start to turn left it seems like i lack power and bike does not want to go . no problems when i turn right ... i recently re built my motor.. it seem maybe like when i turn left im pinching a line or something like that ,, any help or advice would be great thanks !!!!!!
thanks i will look into that , but here is something eles is it possible when i hooked back up the oil and carb cables i put them in the wrong place for example . lines should be over the frame rail or under frame rail do you think this would cause the problem ??????
the cables should be behind the frame rail...but i do not think that's your problem...something is constricting the motor...maybe wen u turn the handle bars the gas line is getting pinched...I am curious when you do turn it to the left does the motor begin back firing or making funny noises?
ok ok i finally got it !!!!! it was the choke cable , it was ran over the frame under the gas tank.. so i took it off and ran it under the frame and seems to have fixed my problem !!!!! LETS HOPE !!!! but thank alot outlander560 for your help .... NOW LETS GET DIRTY AND MUDDY !!!!!!!
    • By realpilot
    • By Cj Winds
    • By OldATVowner
