haha yea turn the choke on then if it wont start with giving it gas then....
you have to adjust the fuel system i had to do it to because there wasnt enough gas getting to it.
its a 04 when i push the start button noting happens it dont click or noting it has a new battery and still wont star like if its in gear...
You need to check your connections and whip out a meter to test at different points to see if you are getting voltage. Are there lights that light up? See if there is juice getting to the starter solenoid.
* Adjusted your thread title.
Did you try a starter relay/solenoid? If you have electric everywhere else and its not starting, its gotta be a bad starter or a bad relay, I'm assuming. If you have no electric to the headlights brake lights so on, I'd start from the battery then looking at fuses and working your way to the starter. There is a glitch/short somewhere that needs to be fixed/replaced. Hope this helps
  • 3 months later...
  • 6 months later...
    • By Rockbottom
      What should i test next?
      thanks ahead
    • By Mister907
    • By Brent Wright
    • By HeWasRidinDirty
      The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
