Hi all, I took my driven clutch appart because it would not open and close with rmp increase and decrease. The buttons are bad and i will replace those. It came appart fast and I am unsure what holes the srping was in. There is a chart in the book that lists from soft to hard for the settings but was curious if anyone has played with these settings and how much of a difference it has made?
    • By quadnut20
    • By sunn
      The clutch engagement on my 2021 cforce 400s was approx 2700 RPM, very abrupt/not smooth.   I obtained a "kit" from RNG consisting of a blue painted spring (spring force unknown) with 12 gram weights, as measured on my postal scale.  Installation was easy; 18 mm and 30 mm (not 32 mm as seen on other writings) impact sockets for clutch housing removal.  The resultant clutch engagement was still up to approx 2500 and very abupt/not smooth.
      The RNG spring was slightly longer than the stock spring, but felt slightly easier at initial downward force but had more resistance than stock as I continued to push down.  RNG would not tell me what the spring force was.
      I am really struggling to get any answers on the best combination of spring / weights to achieve a smooth engagement of maybe 1800 RPM.  Note; idle RPM is approx. 1600.
      I have searched all the forums and cannot find good information, and RNG appears to be not willing to share information.  What gives here?  Anyone with experience to share?
    • By Coyote251
    • By Mudseeker149
      Just bought the atv, sounds like there’s sand in a bearing near the clutch! Any ideas?
    • By johndeerefarm
      Is there any way to mod an Outlaw 50 to increase the speed? The size is perfect just would like a little more top end speed. Thanks
