Guest Fox300exchic
This is a good video but Im glad I havent seen any crashes like these!
[ame=
[/ame]
Guest Fox300exchic
Oh my God that was horrible, but I couldn't stop watching. Pretty cool video.
Yeah...some were pretty bad.
Guest Fox300exchic
OMG i couldnt finish watching
lol really?!? ohmy
2 of them are from Travis Pastrana videos. The one where the guy makes the right turn when he shouldn't have and the one where the guy tries the front flip with the street bike. Travis should have his own ambulance stationed at his house. Haven't had any this bad myself and I hope I never do.
Guest Fox300exchic
Yeah. Its a mixed video. The ones at Travis' house Ive seen before. I think a few of those were on Crusty Demons.
  • 5 years later...
    • By mikeexplorer
    • By DayBreakJim
      20230725_171507.mp4
    • By George Henry
      While riding a 1985 Honda ATC 200S in the Pine Barrens of New Jersey I had my most memorable crash.  This was over thirty years ago and no injury happened to my trike, me or my buddy Joe.  I was hammering the gas to try to keep up with Joe's faster 1986 Honda ATC 250SX when out of nowhere he stopped.  His brake light wasn't working so by the time I realised he was stopped it was too late.  I lined up my front wheel to his right rear wheel and SMACK!  I flew over the bars and Joe's right shoulder.  I did a flip landing flat on my back in soft sand.  While I flipped over Joe he looked over his left shoulder and missed the whole thing.  We laughed it off and kept riding.
      Add your stories here please.
      p.s. Admin - If this topic was already posted please move it to the appropriate post.
    • By Ulfthednar
      Just a quick test video while I'm learning to use my gopro (really, $250 discount I couldn't pass it up).
      This is from my side drive to the top of the property.
      The Dog loves the runs.
      No snowflakes were injured in the production of this video.
      https://youtu.be/tKjBFuHCkM0
    • By Eric C
      I have looked at every thread I feel like, but with no resolution. Its always the same with a no spark issue:
      Replaced CDI,
      Replaced Pickup Coil (Pulsar)
      Good continuity from CDI to green white wire at ignition coil.
      No Pulse at ignition coil on the green white wire. (testing with test light on Pos of battery.)
      Good 12+ V on the hot side of ignition coil.
      I swapped the wires around on the Pulsar.
      The grounds seem to be good for the blk/y wires throughout bike.
      Brand new battery.
      Brand new stator and Pulsar
      Tried 2 new CDIs
      Brand new rectifier
      I get about 300 Micro A/C volts across the two wires on Pulsar when cranking.
      I am currently cleaning the connections on the rectifier because they were burnt. I am not even sure if it makes a difference because I am told that doesn't produce spark anyway and is only for charging system.
      The fly wheel looks OK, is the pulsar supposed to be connected in the direction with the metal "Button" facing towards the flywheel?
      My bike is a 1995 bayou 300, but I seem to come across same issues on web but no resolution on these things.
