I just changed the oil/filter but did not disconnect any of the hoses from the oil tank to the engine (screen filter hose etc.). Do I still need to disconnect the feed hose and bleed any air out? I don't want this baby to seize down the road. Only thing removed was the filter and drain plug. Thanks in advance for your time....Bill
I think you will be fine, I have never heard anything about bleeding oil lines except for on 2-stroke sleds and PWC's. Your manual probably recommends priming the oil pump, but that is just to make sure oil is distributed quickly upon startup.
I dont know about you but I got a 2006 sportsman 450 and I do have to bleed eny air that is left...I just pinch the hose let it run for about 10 seconds at mid range RPM and then turn it off, you should hear a PSSSSSHHHHHHHHHHH sound when you let go of the hose. i hope this helped.
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By kevinohio
    • By digrig
      Hey everyone,
    • By Rick Shropshire
    • By Ironworker709
      I have Grizzly 700 that has been pretty much totaled out in a bad accident, but it will still run and drive good...
      Will this engine swap into any of the Yamaha UTV's like thr rhino and Viking 700's?
      Was just going to sell it as is for a engine for someone who needs one pretty cheap..but been thinking about getting a UTV for the family and maybe find one with a blown engine cheap and swap it out
      I already an excellent shape 2001 Big Bear 400 4x4 for us..but kinda been looking for a good used UTV for us and the grandkids on our property to play with
      Not sure of the year..i can't remember what year it was when i picked it up for a buddy a few years ago..he went to jail after he totaled this thing and told me to pick up a few things at his house he was renting and just keep them for myself since he owed me a bunch of money before the landlord sent them to the dump...
      The first picture is when i went and picked it up for him..second is how it is now..frame is all twisted up and plastics are fubarred..going to sell the rims and tires.they stick out way too wide on my Big Bear
