By That229Yamaha
Hey guys, I’m new to the forum. What I got is a 2001 Yamaha Bear Tracker 250, got it as a project on trade and the problem I’m dealing with is a “no spark” problem and been trying to hunt down the cause for two weeks. I’ve replaced the stator, pick up coil, CDI, wiring harness, ignition, coil pack, spark plug, solenoid, battery, etc. and I’m still not getting any luck. Even tried bypassing the kill switch. I also noticed two things on this quad, another CDI under the back plastic by the voltage regulator, and a blue and green wire coming from the motor behind the foot shift, tried to hook it up but it broke off and I’m thinking the broken wire would cause it to have no spark, if not then I need someone’s help on this and wanna see if I can get spark again. If anyone knows why I have this problem, the help would be greatly appreciated.
By Sycoholic
I've always loved trikes. My son apparently must've picked up on that. Not only did he surprise me with an 85 Big Red to restore, but he picked himself up an 85 Tri-Z to restore as well. He's definitely got a lot more money and labor wrapped up into his, but damn she looks sweet. Just finished his this week and he just can't stop staring at it. I tell the kids they'll be burying me with my Big Red.
By Rich1028
Yamaha 225 DT
first two pictures of how it looked when I picked it up, last picture is today, I started by taking the racks off, and the windshield, and the seat. working on taking the rear fenders off to look at things next.
By fartknocker
My experience for my 98 sportsman. .keep on mind it has the smaller rear rim so my tire choices are not all that great ...
Best... Goodyear mud terrain. Long lasting awesome all around great tire. No longer available of course
Worst. ...super swamper vampire . Too soft. Ended up on gravel a few times over a few months of winter snow riding. . Burned down from 1.5 inch paddle to 1 inch in no time. Junk. But if you are able to 100% stay in soft terrain they are insane
Current. . Mud lites . Pretty decent. But I miss my Goodyears
By MaxPax
Backstory: ATV Ran fine, once stopped in the forest and had to be towed back to my workshop. Found that the stator connector was melted together. Fixed that and it ran mostly fine but intermittently lost spark. Changed CDI box which fixed that problem. Ran fine for a year, but started to misfire more and more often until it did that most of the time. It's not really losing spark, it's firing when it's not supposed to, occasionally making the engine kick in the wrong direction if the revs are low enough. I found that disconnecting the charge regulator would make the problem disappear. I measured the regulator, one diode seemed bad so I got a new one. No change. I then bought another new CDI box and changed the stator and ignition sensor as well as the ignition coil to make sure everything in the ignition circuit was new.
And now, it's still doing it. I'm leaning to a broken cable/connector somewhere but it seems illogical to me that it would spark when not supposed to if it were that. Any suggestions is very much appreciated!
