I need to change the oil and filter in my daughters 2003 lt250 ozark four wheeler and i dont have the owners manual, could some one please tell me where the filter is located and what kind of oil i need ??? PLEASE!!!!::confused:
Hi Im Drew my screen name kinda gives it away lol I got a 250 quadrunner its a 2001 the oil filter is a cartridge type. its not real easy to find on mine the motor has an oil level sight glass window.right above or below it is a small round cover bolted to the motor any how you can take that bolt or bolts out and the cartridge comes out on mine its on the right side almost behind the right rear tire it was easier to get to by removing the wheel the cover for it on mine was about the size of a silver dollar the sight glass has two horrizontal lines the oil level should be in between thoses lines when its warm mine uses 10w40 but my 400 eiger uses 20w50 the fill hole is on the rear differential on mine it says 10w40 on mine I am not familiar with the ozark but its possibly similar they made some changes to the 250 motor around those years I think this might help but not sure its a start good luck and let me know how you make out ,Druzuki
    • By cavry
      Cavry
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
    • By flyinbrian365
      What's Covered:
