1998 Polaris Explorer 400 Starter Not Working
hey all. i just aquired a 1998 polaris explorer 400. the starter doesnt work. i tapped on the starter as i held the starter button in. it will turn over very slow. this was with my charger hooked up to battery. would my starter be screwed, or would it be the solonoid. when i hit the button i can hear the solonoid click. any ideas would be appreciated.
  • Similar Topics
    • By alexwv1863
      Hey everyone, I have an issue with my dad's 03 Yamaha Kodiak 400. It had been running great but he left it sitting for a short amount of time. When he started it, it ran fine for a little bit but all of a sudden it quit taking gas. I thought it may have been the carb because it him not running it. The carb ended up being pretty clean. He put it back on and after taking it off and cleaning again, I'm beginning to wonder what it could be. It'll start and idle just fine, but when you go to give it throttle, it'll die out. It sounds like it's not getting air right but idk where to look or what else it could be. I'm stumped and need to figure this out before I go crazy. Anyone have any ideas???
    • By mfay1
      Can anyone tell me where the fuses are on a 2005 Polaris Sportsman 400. The winch suddenly stopped working. I put a tester on it and its not getting any juice. Please help! (I dont even know if the machine has a fuse for that)
    • By ggreen
      Sorry if this is in the wrong section,I didn't really consider it technical or needing advice. 2006,Linhai 300cc.What I was hoping was to find someone with the starter idler gear pin length and diameter. I've had the cover off alot of times and never realised there should be a pin from the case that meets the cover holding the starter gear in place. Now,a deepwell 1/4 in drive,5/16 deep well sits in the pin holes perfectly. Should I cut a lock ring groove in the end of it like a factory pin? I was thinking of just tack welding a washer to the end?
    • By 800CCBRAAAAAAP
      I tested the stock OEM coil, and got 25ohms.  But even after applying voltage, I cant get anything to magnetize to the coil  Does anyone have a way of testing the 4x4 on-demand coil?
  • Similar Tagged Content
  • Gallery Images
