That is a nice clean Blazer you got there. I too have an S-10 Blazer sitting on 33's, it's older and looks a little rough, but it gets the job done. It has a solid axle conversion, a narrow track Jeep Wagoneer donated a Dana 44 front and AMC model 20 rear. I plan to put a small block in it soon, just looking for a tranny.
Nice, looks tough, i just picked up a 96 blazer and i am currently swapping in a 68 327 with a tunnel ram and 1150 dominator carb, and a th-350 trans, the rear axle is getting swapped out from the 7.5 to the 8.5 limited slip. i am planning on dropping it a couple inches and adding ground effects making it a street ride.
you know i wonder bout that myself. the 97 4drs got old type front clip my 96 however has the newer style headlights and grille. i have seen other 97 4drs with the same old 95 style too. i have no idea why they made them like that. the 97 zr 2 door has the new style yet the 4 door dont. its just wierd. btw i have different bumpers on it that are more prerunner style and look better, ill update pics soon. and get some of the v-8 project goin on
    • By gatorschevy
      just picked this one up and was wondering how you know for sure the the 2-stroke oil is going into the motor? I don't want to blow this thing up; I know I can unhook up the parts and just mix it myself but that's another can sitting around
    • By highlifter22
      Good evening, looking to up grade my clutch springs. There are so many different colours and combinations. Looking for the best colour combo. Any help is greatly appreciated 😊
    • By gatorschevy
      Just picked up this thing for the wife but she doesn't care for the purple, so I am going to paint the purple parts sea something (teal) does anyone know where I can get a seat in teal?
    • By nikeplayer
      Anyone have one, and have  experience for a good list of upgrades that will give this thing a little more power?
    • By indyglyder
      Hi, I have an apollo blazer 125 cc with a issue that stator that gets extremly hot.   I replaced the original, then the new one got so hot one wire in the stator melted the solder joint. bought one more and this one also gets hot.  I tested the stator wires and I have continuity to ground.  I think the heat ruined it? or was that my issue.  what can I check to figure out why my stators are going bad.   I did check for continuity between wires to the cdi and reg and they seem fine.  although all the wires seem thin (cheap chinese atvs) i din't find a smoking gun with wire showing high impedence. any advice would be greatly appreaciated.
