yeah is a 88 everything i have seen was for a later model. if i am not mistaken yamaha changed the wiring on later models. making a peice for a 91 unable to work on my atv. i could be wrong if so just tell me
    • By jordan_ATV
    • By Rick Shropshire
    • By dkgg5755
      Im not getting 12v to ignition switch with key off or on I've jumped brown wire from starter relay to positive and neutral light comes on and push button start works. Can't figure out where to go from here any help appreciated l.
    • By Need-help-with-quads
