2008 Suzuki King Quad 450 4x4 light blinking & diff lock stuck on!!!
I have a 08 king quad 450 with a problem. i was going through some mud and came to a stop to push the 4x4 button and diff lock button. made it through the mud but when i came to a stop and disengaged the diff lock and 4x4 the diff lock and 4x4 indicator lights started blinking back and forth and now the 4x4 and diff lock are stuck on. i tried rolling down the hill in N didnt work. disconnected the battery, didnt work. Any ideas?
    • By semicolon
    • By NZrider
    • By jatho
    • By mkibbe
    • By jatho
