Similar Topics
By drobbie98
Hey all, Thanks for having me in the forum. I just purchased my first ATV and am stoked to understand more about it.
The first stupid question will be, what is everyone's maintenance schedule? DO yo follow the recommended intervals or build one yourself based on the machine.
Thanks in advance.
By wiktoriatopajew
Hello . im new on forum , i hope you are well .
I just want to see all ATV with STickers on it Anyone have?
By Gwbarm
By Makj44
Hello I have a 1999 Honda 300 4w/drive and I just replaced the Oem carburetor with a aftermarket carburetor after installing the carb on the bike it started great and idled like new one but when I shifted into first gear and tried to move forward it died, I shifted back In neutral and the wheeler started easy again I let it set there to see if maybe it needed to warm up but when I shifted into first and tried accelerating it died again, I am not a use to working on it and would appreciate any advise thanks
By Angstromm
2005 Suzuki KingQuad 700 4X4 LT-A700X
A bundle of wires taped together shorted and melted tape. After removing tape, the wires fell apart and there was no way to determine how wires connected. This is on the left side of the ATV (see attached pic).
None of the wires run to ground. None test for volts with key on or when ATV is running.
There are 4 wires that go into 3 wires.
4 wires come in from above – yellow/green stripe, white/brown stripe, green, brown.
3 wires are below – all are yellow w/o stripes & and bundled into chase with a blue & a green wire that pass through (see attached pic). The 3 yellows appear to come from generator.
ATV only runs off battery now. There is no charge back to battery and ATV dies upon disconnecting battery (with RPMs up). All fuses are intact.
It would appear that any wire can connect to the yellow wires, so no worries there. But the extra/4th upper wire needs to be connected or bundled with one of its mates and I have no idea which goes to which.
Any help greatly appreciated.
Similar Tagged Content
- 1 reply
- 2,153 views
- 7 replies
- 4,266 views
- 1 reply
- 4,433 views
- 3 replies
- 4,224 views
- 5 replies
- 6,955 views
Gallery Images
