By Cj Winds
By BillR94
Thank you for your time
Bill
By Jason39
I’m having a issue with my choke when its on it runs fine when I cut the choke off the atv cuts off went to take the carburetor off and saw the choke plunger broke at the nut to screw it in could this be my issue? Do I just need to buy a plunger kit and put it on? I took the carburetor off and cleaned both jets anyway just to make sure and it’s still having issues staying on
By austinfuller22
i have a lt 230 and the e start isnt working but i dont know why
can i have some help
By wjmedic
Recently rebuilt front end on this Polaris 400. New axles, bearings, seals, control arm bushings, Hilliard clutch thoroughly cleaned and inspected with no damage noted.
Everything put back to together. Placed bike on jack stands all four wheels off the ground, started in 2 WD switched to AWD both front tires spinning, when AWD turned
off right front wheel will not disengage from AWD. Checked voltage at connectors both left and right connectors have no voltage with AWD switch off, and both have 12.4V
when AWD switch is turned on. Repeated turning switch on and off several times with no change in condition. I am thinking this must be something mechanical with the
Hilliard clutch on the right hub ie. weak spring or stuck rollers on the Hilliard clutch assembly (Is this a logical thought?) any ideas on trouble shooting this before I disassemble the
right front hub again
